demonick's avatar
demonick
CM600 won't negotiate 800down/100up
Thank you!
I am experiencing the exact same issues as the OP. Xfinity, an 800 Mbps upgrade activation, and just seeing 400/24 Mbps. Ordered a CM1100.
After Xfinity installed the boot file, d11_m_cm600_superfast_c01.cm, I can't log in to the modem with either my changed creds or the defaults. Could do a factory reset, but going to leave well enough alone until the CM1100 arrives.
