KingsKid17
Sep 04, 2017Aspirant
CM700 - Network Activity LED
I just installed Netgear Nighthawk AC1750 Smart Router. (BTW...performance increase? WOW!) Prior to this installation, Network Activity LED was showing normal, green, flickering according to netwo...
- Sep 04, 2017
your laptop or whatever you connected to the Router via hardwired ethernet connection is running on 10/100 Mbps and not Gigabit. thats why it shows BLINKING AMBER LED.
vkdelta
Sep 04, 2017NETGEAR Employee Retired
- vkdeltaSep 04, 2017NETGEAR Employee Retired
you can find quick start guide and user manual in PDF format on netgear support website.
- KingsKid17Sep 04, 2017AspirantWould an (old) HP LaserJet 4250, hardwired to the router, cause the same thing?
As long as it is not warning of a problem, I am okay with it. Just paranoid, after a month-long wi-fi battle! First ISP line cut, then upgraded modem, per cable guy recommendation, then router because of wi-fi calling (T-Mobile) issues.
Still have antique printer and PC. Those may not get upgraded for a while! LOL!
Anyway, thank you for the answer. Helped a lot!- vkdeltaSep 05, 2017NETGEAR Employee Retired
what Router do you have?
- KingsKid17Sep 05, 2017AspirantNet gear Nighthawk AC1750...WOW!
