Duckdoger
May 24, 2017Aspirant
CM700 Administration
Can anyone help. I can access the CM700 through Netgear genie but a limited menu comes up. Only tabs visible are Basic and Advanced and each has a very limited number of selections. I'd like to do...
DarrenM
May 26, 2017Sr. NETGEAR Moderator
Hello Duckdoger
The CM700 is a modem not a router you would need to log into your router in order to port forward.
DarrenM
- DuckdogerJun 02, 2017Aspirant
Hey... thanks DarrenM, good point however would you know how to get to the larger menu offerings. I can see a larger menu when first logging in but then it quickly reduces down to limited options. Almost like logging in with a role lesser than an admin role.
Thanks for the response
Duckdoger
