Duckdoger
May 24, 2017Aspirant
CM700 Administration
Can anyone help. I can access the CM700 through Netgear genie but a limited menu comes up. Only tabs visible are Basic and Advanced and each has a very limited number of selections. I'd like to do...
DarrenM
May 26, 2017Sr. NETGEAR Moderator
Hello Duckdoger
The CM700 is a modem not a router you would need to log into your router in order to port forward.
DarrenM
Duckdoger
Jun 02, 2017Aspirant
Hey... thanks DarrenM, good point however would you know how to get to the larger menu offerings. I can see a larger menu when first logging in but then it quickly reduces down to limited options. Almost like logging in with a role lesser than an admin role.
Thanks for the response
Duckdoger
- DarrenMJun 05, 2017Sr. NETGEAR Moderator
Hello Duckdoger
My guess is you cant and that is limited by the ISP for some reason.
DarrenM
- DuckdogerJun 05, 2017Aspirant
DarrenM... thanks for the reply and info man... appreciate it.
- CharliesTheManDec 03, 2017AspirantHe's correct, that's all that can be accessed. There's a problem I'm having because my ISP has taken a stance that they no longer flash firmware to modems. But netgear doesn't allow firmware updates by users because it's the ISP's job. So we are just stuck in limbo at the moment for using a non ISP modem, as far as firmware updates. Luckily though everything works great.
But as stated above, the menu is limited and you will need to use your router to customize your network and for things like port forwarding. This just gets the signal from ISP to your router.
