sruss's avatar
sruss
Follower
Jul 27, 2019
CM700 Cable Modem Support for two routers
I have a Netgear CM700 Cable Modem and have had it for about 6 months connected to a router. It works fine. I wanted to add a second router so I installed a Netgear Prosafe switch between the original router and the cable modem. That works fine. However I can't figure out how to add a second router to the switch. All i get from a browser when connecting to the second router is No Internet Connection. I did have the second router connected to the first router and that worked fine. However the cabling in my house requires me to use the switch. Any ideas?
1 Reply
  • FURRYe38's avatar
    The CM700 and most cable modems only service 1 WAN IP address.
    Standard networking connect configurations for home class modems and routers and switches are:
    Cable modem>Router>Switch<All wired devices to switch.
    You can't have two routers behind this model modem.
    If your ISP supports having more then 1 WAN IP address, then you would need a CM1100 or 1200 modem. Those support more than one IP address coming from the WAN/ISP.
