yekiMikey
Jan 30, 2023Aspirant
CM700 dropping internet, xfinity claims cable OK
My CM700 is dropping internet regularly and a reboot of the modem generally recovers from the problem the quickest. The following is a log snippet that is representative of the whole event log: T...
Jan 30, 2023Guru - Experienced User
You have Criticals and Warnings that the ISP needs to review and resolve from there side.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
yekiMikey
I am using a tp-link deco ac1200 router. Xfinity claims the cables on their side are OK.
| <tabindex=-1>Startup Procedure</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- yekiMikeyJan 30, 2023Aspirant
I also found my cm700 on the "bad modems" page, I'm wondering if it could be that...
- FURRYe38Jan 30, 2023Guru - Experienced User
Well power levels are good. There a a few Correct and Un-correctables that could be/should be zeros, however don't think those would be a real cause.
Ya the CM700 is a Intel Puma based chipset modem and was on a list that came from DSLReports site.
You could try a different modem, the CM1000, 1100 and 1200 are Broadcom based modems are not effected by the Intel vulnerability. Might try a different modem to see if the problem follows.
