I am using a tp-link deco ac1200 router. Xfinity claims the cables on their side are OK.
| <tabindex=-1>Startup Procedure</tabindex=-1> |
| Procedure | Status | Comment | | Acquire Downstream Channel | 411000000 Hz | Locked | | Connectivity State | Ok | Operational | | Boot State | Ok | Operational | | Security | Enabled | BPI+ | | IP Provisioning Mode | Honor MDD | honorMdd(4) |
| Downstream Bonded Channels |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | UnCorrectables | | 1 | Locked | QAM 256 | 1 | 387000000 Hz | 3.0 dBmV | 37.3 dB | 0 | 0 | | 2 | Locked | QAM 256 | 2 | 393000000 Hz | 3.0 dBmV | 37.3 dB | 0 | 0 | | 3 | Locked | QAM 256 | 3 | 399000000 Hz | 3.0 dBmV | 37.3 dB | 0 | 0 | | 4 | Locked | QAM 256 | 4 | 405000000 Hz | 3.0 dBmV | 36.6 dB | 0 | 0 | | 5 | Locked | QAM 256 | 5 | 411000000 Hz | 3.2 dBmV | 36.3 dB | 0 | 0 | | 6 | Locked | QAM 256 | 6 | 417000000 Hz | 3.2 dBmV | 36.6 dB | 0 | 0 | | 7 | Locked | QAM 256 | 7 | 423000000 Hz | 3.0 dBmV | 37.3 dB | 0 | 0 | | 8 | Locked | QAM 256 | 8 | 429000000 Hz | 3.0 dBmV | 37.3 dB | 0 | 0 | | 9 | Locked | QAM 256 | 9 | 435000000 Hz | 3.0 dBmV | 36.6 dB | 0 | 0 | | 10 | Locked | QAM 256 | 10 | 441000000 Hz | 3.0 dBmV | 37.3 dB | 0 | 0 | | 11 | Locked | QAM 256 | 11 | 447000000 Hz | 3.0 dBmV | 37.3 dB | 0 | 0 | | 12 | Locked | QAM 256 | 12 | 453000000 Hz | 3.0 dBmV | 36.6 dB | 0 | 1 | | 13 | Locked | QAM 256 | 13 | 459000000 Hz | 3.2 dBmV | 36.6 dB | 0 | 0 | | 14 | Locked | QAM 256 | 14 | 465000000 Hz | 3.0 dBmV | 36.6 dB | 23 | 0 | | 15 | Locked | QAM 256 | 15 | 471000000 Hz | 3.2 dBmV | 37.3 dB | 0 | 0 | | 16 | Locked | QAM 256 | 16 | 477000000 Hz | 3.4 dBmV | 37.3 dB | 7 | 0 | | 17 | Locked | QAM 256 | 17 | 483000000 Hz | 3.5 dBmV | 37.3 dB | 0 | 0 | | 18 | Locked | QAM 256 | 18 | 489000000 Hz | 3.7 dBmV | 36.3 dB | 4 | 0 | | 19 | Locked | QAM 256 | 19 | 495000000 Hz | 3.7 dBmV | 37.3 dB | 7 | 0 | | 20 | Locked | QAM 256 | 20 | 507000000 Hz | 4.0 dBmV | 37.3 dB | 0 | 0 | | 21 | Locked | QAM 256 | 21 | 513000000 Hz | 3.9 dBmV | 37.6 dB | 0 | 0 | | 22 | Locked | QAM 256 | 22 | 519000000 Hz | 4.0 dBmV | 37.6 dB | 0 | 0 | | 23 | Locked | QAM 256 | 23 | 525000000 Hz | 4.1 dBmV | 37.3 dB | 0 | 0 | | 24 | Locked | QAM 256 | 24 | 531000000 Hz | 4.5 dBmV | 37.3 dB | 16 | 0 | | 25 | Locked | QAM 256 | 25 | 537000000 Hz | 4.4 dBmV | 37.3 dB | 7 | 0 | | 26 | Locked | QAM 256 | 26 | 543000000 Hz | 4.4 dBmV | 37.3 dB | 1725 | 0 | | 27 | Locked | QAM 256 | 27 | 555000000 Hz | 4.5 dBmV | 36.9 dB | 97 | 625 | | 28 | Locked | QAM 256 | 28 | 561000000 Hz | 4.5 dBmV | 36.9 dB | 10 | 0 | | 29 | Locked | QAM 256 | 29 | 567000000 Hz | 4.8 dBmV | 37.3 dB | 18 | 0 | | 30 | Locked | QAM 256 | 30 | 573000000 Hz | 4.9 dBmV | 37.6 dB | 0 | 0 | | 31 | Locked | QAM 256 | 31 | 579000000 Hz | 4.9 dBmV | 37.6 dB | 0 | 0 | | 32 | Locked | QAM 256 | 32 | 585000000 Hz | 5.0 dBmV | 37.9 dB | 0 | 0 |
| Upstream Bonded Channels |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 8 | 5120 Ksym/sec | 16400000 Hz | 44.5 dBmV | | 2 | Locked | ATDMA | 7 | 5120 Ksym/sec | 22800000 Hz | 44.8 dBmV | | 3 | Locked | ATDMA | 6 | 5120 Ksym/sec | 29200000 Hz | 44.8 dBmV | | 4 | Locked | ATDMA | 5 | 5120 Ksym/sec | 35600000 Hz | 44.5 dBmV | | 5 | Locked | ATDMA | 10 | 1280 Ksym/sec | 39600000 Hz | 41.5 dBmV | | 6 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 7 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 8 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
