yekiMikey
Jan 30, 2023Aspirant
CM700 dropping internet, xfinity claims cable OK
My CM700 is dropping internet regularly and a reboot of the modem generally recovers from the problem the quickest. The following is a log snippet that is representative of the whole event log: T...
Jan 30, 2023Guru - Experienced User
Well power levels are good. There a a few Correct and Un-correctables that could be/should be zeros, however don't think those would be a real cause.
Ya the CM700 is a Intel Puma based chipset modem and was on a list that came from DSLReports site.
You could try a different modem, the CM1000, 1100 and 1200 are Broadcom based modems are not effected by the Intel vulnerability. Might try a different modem to see if the problem follows.
