TheTwinky
Jul 30, 2017Follower
CM700 Modem - Downgraded services
Fireware Verison: V1.01.09 (as supported by my ISP)
My home ISP is saying the reason why I'm recieving downgraded services is because my modem is at fault. The issues happen once a month for about a week. I bought the CM700 Modem in Feb of this year. I know a bit about computers, but networking is where I lack. I went into my event logs and i was wondering if someone that explain these events showing up. Any help would be useful thank you.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello TheTwinky
You have alot of T3 timeouts which is typically a issue with the ISP cable lines.
Explanation: The cable modem has sent 16 Ranging Request (RNG-REQ) messages without receiving a Ranging Response (RNG-RSP) message in reply from the CMTS. The cable modem is therefore resetting its cable interface and restarting the registration process. This typically is caused by noise on the upstream that causes the loss of MAC-layer messages. Noise could also raise the signal-to-noise ratio (SNR) on the upstream to a point where the cable modem’s power level is insufficient to transmit any messages. If the cable modem cannot raise its upstream transmit power level to a level that allows successful communication within the maximum timeout period, it resets its cable interface and restarts the registration process. This error message is DOCSIS event message is R03.0, Ranging Request.
DarrenM
