kobo1042
Jun 25, 2020Follower
CM700 seen by ISP but still no internet connection
Successfully installed and provisioned cable modem with Spectrum this morning. Cannot get an internet signal to come thru. ISP said to contact Netgear to help provision it on their end? When I reboot the modem I get the up and downstream icons to lock in solid green and then the internet symbol blinks for 30 seconds and then goes out and the up and downstream icons begin blinking green again searching for a signal.
Log into the cable modem and get a screen snip of the cable connections page and the logs. Post that back here.
Also, check if you have any splitters, amplifiers, or attenuators in line. remove them if you do.
Are you connecting a router to it and if so which one?
For getting it setup, make sure to connect a pc to it and get the modem functioning properly. If you do get a good signal/speed, then follow this procedure for getting the router connected.
1. power off both modem and router and disconnect coax. wait 1 minutes
2. connect coax to modem and then power it on. give it several minutes to fully boot.
3. connect lan cable from mode to wan port on router.
4. power router on. give it several minutes.
5. try setup.
Do you get any internet services with a wired PC directly connected to the modem with out a wifi router in between?
