whatisgoingon's avatar
Jul 26, 2018
CM700/Nighthawk Dropping Internet + DoS/WLAN access rejected spam
All of these problems began showing in the logs a few minutes after updating to V1.2.0.24_1.0.1.  My internet has been disconnecting multiple times a day (modem loses connection).
In the logs I see:
1. Multiple [DoS attack: ACK Scan] from various IP's.
2. Multiple [WLAN access rejected: incorrect security] from my iPhone's MAC address
3. Multiple [WLAN access rejected: incorrect security] from 16 different unknown MAC addresses (a little concerned about this)
I can post the log if necessary but it's very long (6 days worth).  Attached is a picture of the unknown MAC addresses that have been rapidly trying to connect to my wifi (which has a password).
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Not in the router logs but the logs of the modem do you seen any T3 or T4 timeouts?
    DarrenM
    • whatisgoingon's avatar
      whatisgoingon
      I never knew I could login to the modem like this so I'm a bit unfamiliar with the data.  Unfortunately, I recently rebooted the modem to regain internet connection which seems to have cleared the logs.  I do see:
      No Ranging Response received - T3 time-out
      MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
      Downstream
      Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables
      1 Locked QAM 256 17 603000000 Hz -7.7 dBmV 37.3 dB 0 0
      2 Locked QAM 256 18 609000000 Hz -7.7 dBmV 37.3 dB 0 0
      3 Locked QAM 256 19 615000000 Hz -7.2 dBmV 37.3 dB 0 0
      4 Locked QAM 256 20 621000000 Hz -7.4 dBmV 37.3 dB 0 0
      5 Locked QAM 256 21 627000000 Hz -8.0 dBmV 37.3 dB 0 0
      6 Locked QAM 256 22 633000000 Hz -8.2 dBmV 36.6 dB 7 0
      7 Locked QAM 256 23 639000000 Hz -7.7 dBmV 37.6 dB 7 0
      8 Locked QAM 256 24 645000000 Hz -8.2 dBmV 37.3 dB 0 0
      9 Locked QAM 256 25 651000000 Hz -8.2 dBmV 37.3 dB 0 0
      10 Locked QAM 256 26 657000000 Hz -8.2 dBmV 36.6 dB 0 0
      11 Locked QAM 256 27 663000000 Hz -8.2 dBmV 37.3 dB 0 0
      12 Locked QAM 256 28 669000000 Hz -7.7 dBmV 37.3 dB 0 0
      13 Locked QAM 256 29 675000000 Hz -7.2 dBmV 37.3 dB 0 0
      14 Locked QAM 256 30 681000000 Hz -7.2 dBmV 37.6 dB 0 0
      15 Locked QAM 256 31 687000000 Hz -7.2 dBmV 37.3 dB 0 0
      16 Locked QAM 256 32 693000000 Hz -7.2 dBmV 37.3 dB 6 0
      17 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      18 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      19 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      20 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      21 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      22 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      23 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      24 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      25 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      26 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      27 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      28 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      29 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      30 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      31 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      32 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
      Upstream
      Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
      1 Locked ATDMA 2 5120 Ksym/sec 30100000 Hz 54.5 dBmV
      2 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
      3 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
      4 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
      5 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
      6 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
      7 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
      8 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
      54.5 dBmV seems very high compared to the downstream values or is that normal?
      Thanks for the help.
        whatisgoingon
        Just experienced another drop in internet.  Before it would fix itself but now it seems I need to do a full restart to get the internet working.  I was able to grab the log before restarting.
        Modem Logs:
        Jul 31 2018 07:08:17 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:08:17 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:08:46 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:08:47 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:09:31 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:09:31 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:10:04 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:10:04 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:10:45 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:10:45 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:11:17 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:11:17 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:11:47 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:11:47 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:12:23 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:12:24 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:12:55 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:12:56 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:13:40 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:13:40 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:14:20 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:14:20 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:15:02 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:15:02 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:15:42 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:15:42 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:16:11 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:16:12 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:17:04 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:17:05 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:17:36 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:17:36 Critical (3) No Ranging Response received - T3 time-out
        Jul 31 2018 07:18:28 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
        Jul 31 2018 07:18:28 Critical (3) No Ranging Response received - T3 time-out
        And here are some of the router logs.  The logs were empty up until July 20th when I upgraded to the latest firmware, except for one event in May. Not sure if this is a coincidence or not.  This is from the same time as the modem log (router time is behind 3 hours).  Note that this is how the logs look even when I'm not having issues.  The other day it seemed to be allowing access to my phone every 5 minutes.
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:31:49
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:30:34
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:29:17
        [Internet connected] IP address: xxx.xxx.xxx.xx Tuesday, July 31,2018 04:28:47
        [Internet disconnected] Tuesday, July 31,2018 04:28:04
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:28:02
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:26:35
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:25:19
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:23:58
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:22:41
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:21:09
        [Internet connected] IP address: xxx.xxx.xxx.xx Tuesday, July 31,2018 04:20:09
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:19:52
        [Internet disconnected] Tuesday, July 31,2018 04:19:02
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:18:35
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:17:14
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:15:57
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:14:41
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:13:22
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:12:05
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:10:49
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:09:25
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:08:07
        [Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:06:50
