pauliw25
Jan 22, 2016Aspirant
CMD31T - All green lights - no internet
Recently I returned my defective Netgear CMD31t modem to Netgear. This week, a refurbished replacement arrived. Problem: When I connect the replacement modem to my desktop computer and m...
- Jan 27, 2016
pauliw25
I do not know if you have done this yet or not since its a replacement modem Time Warner cable has to re provision the modem and make sure its enabled in there billing system on you account so I would call there Tier 3 tech support have them check and see if they can communicate properly with the new modem.
DarrenM
DarrenM
Jan 25, 2016Sr. NETGEAR Moderator
Hello pauliw25
Do you have a router that the CMD31T is connected to? also try another cord could be a bad cord.
DarrenM
- pauliw25Jan 26, 2016Aspirant
No - the WiFi router is connected to the Ethernet modem. Not the other way around. The Ethernet router CMD31T is directly connected to my Time Warner internet cable.
My Windows 10 desktop is connected to the modem via an ethernet cable - the same cable that worked with the original CMD31T modem.
In seeing that I am using the same cable that worked before - I serously doubt it's the cable, and to be honest - in seeing that I live on a limited budget - I would prefer to avoid purchasing a new cable when most likely the problem is not with the Ethernet cable.
- DarrenMJan 27, 2016Sr. NETGEAR Moderator
pauliw25
DarrenM
