lxwidm's avatar
lxwidm
Coax cable can't screw-in to modem/router.
I tried to screw-in a standard coax cable into my modem/router but it doesn't screw-in. Is there a special coax cable required for netgear?
  • FURRYe38's avatar
    What NG model modem do you have?
    Ask the ISP about what and how to connect to there cable line. RG6 is needed for Coax cable modem ISPs.
  • plemans's avatar
    Take a look at the end of the coax. I've seen them snipped off and the copper wire get flattened a bit. Not a lot but just enough to cause issues when pushing into the connector.
    Got a picture of the end of the coax cable?
    • lxwidm's avatar
      lxwidm
      The problem is the threads don't match. The female  connector in the cable modem/router seems to be thinner than the standard one. I am able to screw the coax cable into all the other devices except this one. Does this require a special coax cable?
      • plemans's avatar
        No its standard rg-6. Do you have a photo of both?
