tomgru
Feb 25, 2018Tutor
Comcast and CM700 speed issues
Been reading the forum... and think there is not much i can do before Comcast tech comes out, but wanted to post here to make sure i had answers ready. few months old CM700 - pay for 150Mbps .......
tomgru
Feb 26, 2018Tutor
here you go...
vkdelta
Feb 26, 2018NETGEAR Employee Retired
your screenshots did not show up. Please attach the files again.
- tomgruFeb 26, 2018Tutor
looking right at them in this thread... you can't see them?
- DarrenMFeb 27, 2018Sr. NETGEAR Moderator
Hello Tomgru
The power on the first couple downstream channels is high it should be between -7 to +7 and the timeouts could be a sign of signal issues. You will want a tech to check the lines or remove any splitters connected to your cable modem and see if it improves.
DarrenM
- tomgruFeb 27, 2018Tutor
Thanks Darren. Tech was there last night and concluded pretty similar... but from tap in neighborhood to my house. Need to run new cable ... will take 2-3 weeks at best. (ugh). At least i have ~30 Mbps still, so i shouldn't complain too much.
Will try to remember to report back and see if that fixes the problem.
