tomgru
Feb 25, 2018Tutor
Comcast and CM700 speed issues
Been reading the forum... and think there is not much i can do before Comcast tech comes out, but wanted to post here to make sure i had answers ready. few months old CM700 - pay for 150Mbps .......
tomgru
Feb 27, 2018Tutor
looking right at them in this thread... you can't see them?
DarrenM
Feb 27, 2018Sr. NETGEAR Moderator
Hello Tomgru
The power on the first couple downstream channels is high it should be between -7 to +7 and the timeouts could be a sign of signal issues. You will want a tech to check the lines or remove any splitters connected to your cable modem and see if it improves.
DarrenM
- tomgruFeb 27, 2018Tutor
Thanks Darren. Tech was there last night and concluded pretty similar... but from tap in neighborhood to my house. Need to run new cable ... will take 2-3 weeks at best. (ugh). At least i have ~30 Mbps still, so i shouldn't complain too much.
Will try to remember to report back and see if that fixes the problem.
