SparroHawc's avatar
SparroHawc
Comcast and DNS hijacking - how to narrow it down?
I can't get through to the DNS server I want to for love or money.
If I set my DNS server address to 1.2.3.4 (not a DNS server), I still get results.
If I get the Source of Authority for a given domain and query THAT for the authoritative result, I still get a non-authoritative result.  (When I'm not at home, this doesn't happen.)
If I set my DNS server to a DNS server that returns different results than normal, I still get the normal results.
I have no idea if it's my router that's the problem, or if the transparent DNS proxy is further upstream.  So, here's what I've tried to do to narrow down where it is.
Set my router's primary and secondary DNS servers to something inside the LAN
Change my computer's DNS server to the router
Repeat the above tests
The router appears to return DNS requests like it's a standard DNS proxy, but it doesn't appear to be using the DNS server on its settings page - I still get DNS results from some mysterious server that I don't know where it is.
I chatted with a Netgear rep, and although I have doubts about how in-depth their technical knowledge is, the impression that I got is that the router itself doesn't actually use the settings I choose - instead, it uses the DNS servers it picks up from the ISP through DHCP.  Including when I send a DNS request to the router.
I know Comcast has a history of putting their customers behind a transparent DNS proxy, but when I called their service people (and got increasingly frustrated with them), they insisted that it was my hardware.
I also know that Comcast pushes firmware updates to customer-owned hardware, so even if Netgear never sells hardware that performs sneaky DNS shenanigans, that doesn't mean Comcast hasn't forced it down my poor router's throat.
Does anyone know how to narrow this down to hardware or ISP, or can just speak from a technical standpoint about this and my router?  I've sunk a full day of research on this and I feel like I'm getting nowhere...
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello SparroHawc
    What the Netgear rep has told you is right I am guessing it has to do with the DNS servers that comcast is pushing down to you but it would be hard to get a hold of someone high enough at comcast to answer that question for you.
    DarrenM
    • SparroHawc's avatar
      SparroHawc
      If I switch the device to bridge mode, would that prevent it from doing any packet modification if it -is- the router that's causing the issue? Can I hook a computer up with an ethernet cable to the device while it's in bridge mode and still be able to hit the internet?
      • DarrenM's avatar
        DarrenM
        Hello Sparrowhawc
        Yes you can but it would be like hooking a PC up to a cable modem directly without a routers protection.
        DarrenM
