David21797's avatar
David21797
Follower
Jun 03, 2019
Comcast Service, IP Phone, R7000 netgear disonnecting every 10 minutes
Just switch from Comcast Business to Comcast Residential.  Didn't want to rent the Comcast box so I purchased a Nighthawk R7000 cable modem device.  Now my IP phone will disconnect like clock work every 10.5 minutes.  Help!
    • antinode's avatar
      antinode
      Guru
      > [...] I purchased a Nighthawk R7000 cable modem device. [...]
      > Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
         An R7000 is not an R7000P, and neither of them is a "cable modem
      device."  What is the actual model number on the product label on your
      device?
         Visit http://netgear.com/support , put in your (actual) model number,
      and look for Documentation.  Get the User Manual.  Read.  Return here
      (or to some appropriate forum) with the actual model number.  The
      firmware version might also be helpful.
      > Please post about this here for your model router: [...]
         Of course, the value of that advice depends on exactly what your
      device is.  (But the accompanying animated icon is very annoying in any
      case.)
