Cherpumple
Feb 25, 2018Aspirant
Compare Products: C7000 vs. C7000-1AZNAS
Hello, I've noticed on both Amazon and Netgear's own website that there are separate product pages for the Nighthawk DOCSIS 3.0 Cable Modem Router. There are two different item model numbers: Mod...
- Mar 05, 2018
Hello Cherpumple
Its just the box that it comes in we made some boxes that are easier to open and more eco friendly but the modems are the same.
DarrenM
vkdelta
Feb 25, 2018NETGEAR Employee Retired
1AZNAS is same, just some minor packaging difference.
C6900 does not have the USB port and is a Costco product. Is not sold in other stores.
- CherpumpleFeb 26, 2018Aspirant
Thank you for the reply.
Would you recommend that I purchase the more recent C7000-1AZNAS then?
And will the C7000-1AZNAS eventually replace the C7000?
Can you perhaps provide me the details on the minor packaging difference?
Thanks again.
- CherpumpleMar 01, 2018Aspirant
Hello?
:catindifferent: :manindifferent: :robotindifferent: :smileyindifferent: :womanindifferent:
- DarrenMMar 05, 2018Sr. NETGEAR Moderator
Hello Cherpumple
DarrenM
