MAK47's avatar
MAK47
Follower
May 14, 2018
Compatible PC OS
I have a Linux OS, Ubuntu 16.04, can this work with a CMV Cable Modem w/telephone jack?
Also, if 'yes', are there any router-limitations using this modem?
Thx
  • Yes the linux box should connect via wifi or ethernet just like any other pc can.
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
