johnparker67
Mar 02, 2019Follower
Compatible Switch with CM1100
I am looking to buy the CM1100 Cable modem and it has 2 ethernet ports that can be channel bonded. I would like to add a swtich where all my ethernet wires are located and connect the switch to the C...
DarrenM
Mar 07, 2019Sr. NETGEAR Moderator
You would want a router connected to the CM1100 and then you can connect the switch that you want to that router.
DarrenM
