mo333
Aug 30, 2016Follower
Configure C6300 for Bridge mode to connect to AC791L Hotspot
Ok, so I have an AC791L hot spot and I want to give it more wireless range and connect ethernet devices to the C6300 and have the C6300 wirelessly connect to the AC791L... I believe this is called a bridge... WIll this work in this configuration? And I've searched but all the owner's manual states is set bridge mode... Well that doesn't work... There must be more to it that I am not seeing... A repeater might do the wireless stuff, but I need to be able to hook up ethernet cables to the C6300...
Pleae help! I am not uing the C6300 s a router for cable internet it is stand alone...
Any pointers to the config docs would be appreciated...
Thanks, M0
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello mo333
I do not believe this will work because when you Bridge the C6300 it becomes a modem only and the router part is disabled so you would have anything plugged into the modem going directly to your internet connection.
DarrenM
