philtbc
Aug 22, 2015Follower
Configuring a Telstra Gateway Max (C6300) to the Optus Network
Hi,
A friend gave me their Telstra Gateway Max (C6300) Wifi Router, and I tried to replace my old Optus Netgear wifi router with it. But it can't navigate out to the NET.
Something hard coded in the Telstra Gateway Max that is not communicating properly with the Optus DNS server, I'm guessing.
Hoping someone can point me in the right direction here, as I don't think a factory reset would help, would it?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello philtbc
If you believe its a DNS issue have you tried to use googles dns to see if you are able to connect out the the net? Hope to hear your feedback
https://developers.google.com/speed/public-dns/?hl=en
DarrenM
