toddmello
May 05, 2017Aspirant
Connect Router To Work VPN
I am trying to configure the Router to connect to my work VPN. I am trying to use a VOIP phone at home while I am connected to the internal domain at work through VPN. This works fine with a softphon...
TheEther
May 06, 2017Guru
You didn't specify the model of your router. Most consumer grade Netgear router do not have any built-in VPN client support.
- toddmelloMay 08, 2017Aspirant
Apologies - I thought it was in the description when I started the thread.
AC1900 - C6300BD It does say IPSEC is an option - just not sure to what degree
Thanks In Advance
