toddmello
May 05, 2017Aspirant
Connect Router To Work VPN
I am trying to configure the Router to connect to my work VPN. I am trying to use a VOIP phone at home while I am connected to the internal domain at work through VPN. This works fine with a softphon...
toddmello
May 08, 2017Aspirant
Apologies - I thought it was in the description when I started the thread.
AC1900 - C6300BD It does say IPSEC is an option - just not sure to what degree
Thanks In Advance
TheEther
May 08, 2017Guru
That's probably the IPSEC passthrough option. That only means that it won't block that traffic.
- toddmelloMay 08, 2017Aspirant
I did read that part. This modem is from my local cable company. Can you suggest a Router with the VPN capability I am looking for?
- TheEtherMay 08, 2017Guru
I'm gonna bet that you are using the Cisco Anyconnect VPN client. This is designed to provide VPN access for the computer it is running on. As such, you won't be able to run it or anything equivalent on a router. It would also probably be against your company's policy to set up VPN access on your router without your company's knowledge. Think of the security implications. If your network is not secure, you will have just opened up the entire company to being hacked.
You really should discuss your needs with your company's IT department. If they support these kinds of requests, they can supply you with the equipment to set up a site-to-site VPN.
