clgray
Oct 13, 2015Aspirant
Connecting a Verizon Jetpack(mifi) to CG3000DV2-RG
I recently purchased a CG3000DV2-RG modem/router and I'm attempting to tether a personal Verizon Jetpack mifi device to it as the source of the internet. There are USB ports on the router so I assume...
vkdelta
Oct 14, 2015NETGEAR Employee Retired
I assume you are asking for USB 4G WAN backup (verizon MIFI will be used for WAN connectivity and coax cable will be disconnected).
it is not support for CG3000Dv2
clgray
Oct 14, 2015Aspirant
No - I am asking about the verizon 4g mifi. I want to use that as the internet connectivity. How can I do that?
- DarrenMOct 15, 2015Sr. NETGEAR Moderator
Hello clgray
Those USB ports cant be used for Internet connection they are ment for printers and storage devices.
DarrenM
- clgrayOct 15, 2015Aspirant
Does netgear have any products that would fit for that functionality?
- DarrenMOct 21, 2015Sr. NETGEAR Moderator
clgray
There is the aircard cradle that gives better wifi coverage ethernet ports and charges the aircard.
http://www.netgear.com/home/products/mobile-broadband/hotspots/DC113A.aspx
DarrenM
