registradus's avatar
registradus
Follower
Apr 07, 2018
Connecting Billion 7800VPDX to Netgear CM500V
I'm trying to use the Billion 7800VPDX as a wireless router for the Netgear CM500V cable modem (on Optus Cable).
I've plugged the ethernet cable from the Netgear to Ethernet 4 (EWAN) on the Billion.
I've set the connection type to PPPoE. I've set the username to my @optusnet.com.au account and password.
I've set Q VLAN ID tag to "2" and 802.1P Prority to "0"
I've tried turning off the Netgear modem for 15 minutes.
But I can't get it to work.
any help would be appreciated
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Do you get a internet connect directly from the modem?
    DarrenM
