blaketm's avatar
blaketm
Connecting C3700 to R7000 (AC1900)
How do i connect Router-Only model R7000 (AC1900) to a C3700 combination modem/router, so i can use the higher R7000 router capabilities.
  • > How do i connect Router-Only model R7000 (AC1900) to a C3700
    > combination modem/router [...]
       Use an Ethernet cable?
       What you may want in this case is to configure the R7000 as a
    wireless access point.  Visit http://netgear.com/support , put in your
    model number, and look for Documentation.  Get the User Manual.  Look
    for "Wireless Access Point".
    • blaketm's avatar
      blaketm
      Thanks antinode, it seems to work in both Router and Access Pt modes.  Not sure what the difference is.  Does one give larger wifi range?  Thanks
      • antinode's avatar
        antinode
        Guru
        > [...] it seems to work in both Router and Access Pt modes.  Not sure
           For some purposes, you might not notice any difference.  The
        difference is between having one extended subnet (router plus access
        point) versus two different subnets (two full-function routers).  The
        two-cascaded-routers scheme can cause problems ("double NAT") for
        incoming connections, and for communications between devices within your
        LAN(s).  The radios should be unaffected.
           If you check the IP addresses of client devices which are connected
        to the two router-like gizmos, then you should be able to spot the
        difference(s) between the two arrangements.  Unless you have some good
        reason to have two full-function routers, you'll probably have fewer
        problems with the single subnet in the router-plus-access-point
        configuration.
