Kstop1202's avatar
Kstop1202
Follower
Nov 27, 2017
Connecting modem and router
Because my house is old and has plaster walls my signal was low. I was advised to get a modem and a router that i could link. My upstairs has the modem and original wifi signal and it is eithernet cable linked to my downstairs router. My problem is they have different user name and passwords. Is there a way to make it the same so my electronics dont have to bounce back and forth?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    No they are 2 separate networks you would need a mesh system like Orbi to do this.
    DarrenM
    • antinode's avatar
      antinode
      Guru
      > [...] My upstairs has the modem and original wifi signal and it is
         What, exactly, are "the modem" and "my downstairs router"?
         Assuming that "the modem" is a modem+(wireless)router, then why not
      configure your "my downstairs router" as a wireless access point, and
      use the same wireless credentials on both?
      > to do this.
         Really?  What's the purpose of a wireless access point?
      • CharliesTheMan's avatar
        CharliesTheMan
        Ive done the access points on the same network name and password. The only problem is your devices sometimes will grab onto one access point. Like of you connect upstairs and go downstairs, then they don't switch to the other one always perfectly so you'll have to toggle the Wi-Fi off and on like on the phone to connect to the nearest one.
        Some devices transfer great and it's not a problem, but you'll just have to do some trial and error.
        Make sure you're on the same frequency band and network SSID and password are the same. Make sure you know the IP address of each for when you need to log into the routers control panel or interface to make changes.
