caligreen805
Jan 24, 2017Follower
connecting NETGEAR CM1000 to Cisco DPC3825 modem/router but use DPC3825 as router
OK where to begin? My ISP is cox cable my new cable modem: Netgear CM1000 old cable modem/router: Cisco DPC3825 i recently set up my new NETGEAR CM1000 with them. it works fine and all but i d...
DarrenM
Jan 26, 2017Sr. NETGEAR Moderator
Hello Caligreen805
If the back of the cisco unit does not have one of the port labeled as WAN and you find no options in the settings to run as only a router then this will not work.
DarrenM
