DS404
Apr 11, 2016Aspirant
Connection drops 5-6 times per hour
Since 4/1 I've been having issues where my wifi connection will drop on multiple machines (OS X & Windows 10). The wifi connection will disappear and when I attempt to rejoin the network my system w...
Bettyliciouz81
Apr 12, 2016Aspirant
Same here I'm getting the same issues have you by any chance fixed your problem ? If so can you email me with it please !!! Bettyliciouz81@gmail.com
DS404
No luck and no response yet however if I'm able to fix the issue or receive a response I will let you know.
Have you noticed your speed decrease as well?
- DarrenMApr 18, 2016Sr. NETGEAR Moderator
Hello everyone
What isp does everyone have? and does the internet just go out on the wifi or is it both the WIFI and LAN connections?
DarrenM
- DS404Apr 20, 2016Aspirant
I'm with Comcast and as far I know it's just wifi and not the LAN connection.
What's odd is that I sometimes I can connect to the 5G network (or non-5G depending on which one I'm currently connected to) and it works after the original network kicks me off.
I've set my channels to ones where there is no other traffic.
- DarrenMApr 25, 2016Sr. NETGEAR Moderator
Hello DS404
You may want to contact Netgear support if this keeps happening may be a issue with the hardware of the wifi if all your devices are having this issue.
http://www.netgear.com/support/contact.aspx
DarrenM
