patvelaz
Feb 17, 2021Follower
Connection issues
Hi, I recently moved from Georgia to Florida and transferred my Xfinity service. My Nighthawk C7000-100NAS modem worked fine prior to the move, but when I tried to connect to it in Florida, the s...
michaelkenward
Feb 18, 2021Guru - Experienced User
patvelaz wrote:
...none of the networks I created when I originally sent it up.
Not sure I follow that bit. What networks were these?
patvelaz wrote:
I tried to reset it but no luck.
What did you actually do there? A factory reset?
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Have you confirmed that the C7000 is compatible with your new Internet service?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
