Guzzialfa
Nov 14, 2021Tutor
Considering a CAX80 Purchase -
I am contemplating the purchase of the Netgear AX6000 (CAX80) Cable Modem with WiFi 6 Router. Before I do I have two considerations that are make it or skip it considerations. For Home and Business...
- Nov 19, 2021
Guzzialfa wrote:
Yikes! That's a lot of gear! You say it's all behind the one cable modem, CAX80?? I wanted to ask why you disabled the WiFi and just bought a cable modem only sans WiFi with all the routers you have in place? Then, if all hits the fan, you still have a WiFi solution on the Cable Modem just in case, I suppose.
As plemans mentioned, we do lots of playing with toys and learning of what different products do so we can gain more experience to better help users out here in the forums. So we test out different things and different configurations. We also try to test out new FW as it comes out to see what new things are seen. Give feedback to NG and users.
Was there another reason?
Apologies but what is LAG? Don't recognize the acronym but it is 1:15 AM as I type this.
https://en.wikipedia.org/wiki/Link_aggregation
My apologies for the tardy reply as well. You were very quick to respond as well. I just needed a bit to digest all the different replies. No one from NetGear has responded stating these old Switches will be just fine. Should be is what I get from everyone. Then again, I could just do what you've done and get another 4 port Router and plug in the two switches while also disabling the WiFi on the CAX80. It's an alternative should it be necessary.
Your NG switches should work just fine behind the CAX80.
Or is everyone hinting I shouldn't use NetGear's WiFi and not coming out and saying so?
The CAX80s wifi is pretty good. When I have the wifi on my CAX80, since my home is kind of big, I use two EX7700 wifi extenders to help with signal.
Guzzialfa
Nov 19, 2021Tutor
Thanks again! One last quick question for you. Why did you choose the EX7700 over the AX600 (EAX80). The EX7700 appears to be WiFi 5 while the CAX80 and the EAX80 are both WiFi 6?
Thanks!
John S.
Nov 19, 2021Guru - Experienced User
I already had two EX7700s. They worked. I never go a EAX80 long term though I did test one out for a short period of time.
- GuzzialfaNov 19, 2021Tutor
That makes sense. Use what you have. I should think the EAX80 is the proper fit for the CAX80 and it has the benefit of being a bit less expensive.
My current nightmare - truly mind boggling is I decided to place the order late last night for the CAX80. I missed a text from the bank card saying - hey did you buy this expensive thing? I lantern by sea for yes and 2 lanterns, well you get the idea.
I responded later and at 2:29 AM the bank replied, okay - the hold has been removed, tell your vendor to submit again.
Called the support order line and kept getting her saying - call your bank and release the hold. Finally getting a word in I said - I DID! You need to resubmit. Netgear Support for Orders OR the entire order system has no way to resubmit an order. No way to cancel an order with the status of Exception and I have no way on my account to cancel an order that has not been processed!Nightmare, right? I tried to order again at her suggestion. Tried 3 times adding to the cart and each time there is NOTHING in my Cart! Nada. I cannot do any adding, ordering or anything until this resolves.
No pleading to escalate to a supervisor got me anywhere but we'll call within 24 hours....
I was better off ordering from Amazon!
Linksys anyone? Sigh. I honestly am stuck and have no clue what to try to do next other than wait and see if anything at all happens. Don't know anything could while their waiting for the bank to do something and the bank is waiting for them to resubmit. Catch 22 anyone?
Any thoughts anyone?
Perplexed, John S.
- FURRYe38Nov 20, 2021Guru - Experienced User
Yes, of course the EAX80 is perfect match for the CAX80. Something to try out and see how it works for you.
IF find that Amazon has good return policies. I use Amazon mostly.
Sorry, I left Linksys years ago and haven't looked back. After the WRT1900AC i bought and experiences there, left a bad taste for me. :smileyfrustrated:
