KR4077
Mar 25, 2017Aspirant
Considering Xfinity High speed Internet 150Mbps and up
Does anyone know what Xfinity-approved high speed wi-fi modem works best with the Dell Optiplex 760 desktop using Windows 10? As far as plans go I want 150Mbps or better. I was reading Amazon reviews...
William10a
Mar 25, 2017Master
The computer can support a 1gb lan connection here are the specs for the computer http://www.dell.com/us/dfb/p/optiplex-760/pd
If you want to go the wifi route you install a wiresless card in the computer.
The max speed you can run on the internet is 1gb but the true max is what you can afford and the max speed offer by the isp no matter what you get the copmuter lan port should handle it.
KR4077
Thank you for your help. I have another question. Is the wireless card that you're recommending the same as the wireless adapter ( ex. RealTek RTL8188EU Wireless LAN 802 usb 2.0) ? Or are they unrelated ?
- William10aMar 26, 2017Master
The wifi card is a wireless lan card that plugs in to a slot on the mother board but the usb based wifi adapter will be the easiest to find keep in mind that as with all wifi signals in a home it is a game of chance to the best signal.
