alocksley's avatar
May 05, 2017
Continuing C6300 Modem Router Readyshare No USB Drive
this was a thread closed for lack of activity.  However, I've had a USB drive connected to the port of my C6300 for a couple of years, and all of a sudden the drive is no longer recognized.  The drive works when connected to my PC, and another drive that works on my PC also does not work on the C6300.
Question: is it possible that the latest firmware release -- I have 2.01.18 from TWC -- no longer supports the USB drive, or perhaps requires this new "vault" thing with a new genie??
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Alcocksley
    Have you tried a usb jump drive? it possibly could be a firmware issue or the usb may have something wrong on it.
    DarrenM
  • The usb drive works fone when connected directly to the pc. A seco d usb drive that alao works fine on the pc also isnt recognized by the router.
    What's a "jump drive"? Shouldnt the usb drive work since it worked before?
    Any other reports of firmware problems with 2.01.18?
    • alocksley's avatar
      alocksley
      Tutor
      No other answer?  By "jump drive" if you mean USB drive well that's what all this was about in the first place.  Even a thumb drive doesn't work.
      Anyone else seen issues with the firmware upgrade?  Even tried factory reset, but then the ISP will sense the downlevel and reflash the firmware.
      SUggestions?
      • waterpass's avatar
        waterpass
        I'm experiencing the exact same issue. I got Segete 750GB not recognized but it seems to be ok with a smaler HDDs or thumb drives.
        Is there a cure?
