FTinDFW
Apr 02, 2018Aspirant
Correct setting for "Disable port scan and dos protection" in C3700
Hi Expert, What should be the correct setting for "Disable port scan and dos protection" from Advanced>WPS Wizard>Setup>WAN Setup After I did a factor reset, The box is checked in "Disable port s...
DarrenM
Apr 04, 2018Sr. NETGEAR Moderator
Yes you will want to un check the box so it is enabled.
DarrenM
- FTinDFWApr 06, 2018Aspirant
Thanks to your response. I'll try iy out and hopfully no more
[DoS attack: Illegal Fragments] from 139.12.155.0, port 0Have a great weekend.
BR//Frank
- FTinDFWApr 16, 2018Aspirant
No matter I check or un-check this setting. This entry still exist from time to time to differebt target address(all over the world - USA, Europe, south america, ...
[DoS attack: Ping Of Death] from 139.12.155.0, port 0
Target IP:
72.106.126.106:0
181.235.103.18:0
65.197.193.196:0
136.227.151.143:0
108.217.98.8:0
1.252.34.44:0
Source always this 139.12.155.0, port 0.
Any comments and suggestions is appreciated.
Thanks
Frank
