FransVerhoeve
Nov 28, 2018Aspirant
Could not detect ip-adress camera
First a bit of spec's đ
- Home network
- PoE Switch: Netgear ProSafe GS108PE
- Camera: Hikvision DS2CD2345FWDi 2.8
The appendix shows how my home network is structured. I can "see" the Nas, HDD and the printer via my iMac.
Now I would expect that, after the camera is connected via the PoE switch, it should also be visible.
To detect the camera (IP address) I use the program "iVMS-4200â for Mac. Unfortunately, this program can not detect the camera in the LAN.
Meanwhile, I have once turned everything on and off to see if the camera could be detected afterwards. Unfortunately ..
I made a "map" of the network and at first glance I can not discover anything strange. According to the schedule, the camera should be in the same network as my iMac.
I have to say that I am not really ICT-technical and am more concerned with "Trail & Error".
I hope I can get some tips from you ... đ
Best Regards,
Frans
Hi antinode, thanks for your quick response. Meanwhile I have found out that the IP camera has a different IP range than my network. No wonder then that I can not detect it. How did I fix it:
- First I took a laptop and gave it an IP number that fell in the same range as the camera.
- Then I found the camera and adjusted the IP address to that of my network.
- Then I have detected the camera in my network and have been able to make the necessary adjustments in the camera.
Thanks again for thinking along.
Best Regards,
Frans
> [...] I made a "map" of the network and at first glance I can not
> discover anything strange. [...]
It looks ok to me, too. Does the router have anything like an
"Attached Devices" or "DHCP clients" report which would show the IP
address of the camera? If you connect a computer directly to the same
switch as the camera, does that change anything?- FransVerhoeveAspirant
Best Regards,
Frans> [...] the IP camera has a different IP range than my network. No
> wonder then that I can not detect it. [...]
For any device which does not have a simple user interface (like,
say, an IP camera, or anything which lacks an actual keyboard and
display), there are advantages to using DHCP instead of a static address
(configured on the device itself).
With DHCP, any new device should get a valid (local) address the
first time, and, if you need to specify a fixed address for the device,
then you can reserve an address for it on the DHCP server (typically on
the router).
Glad to hear that you got it to work.
