ScottZ013's avatar
ScottZ013
Could There Be A Provisioning Issue?
I got a new Netgear C7000v2 for my Optimum Online service. I pay for 200DL/35UL. With this modem/Router connected, I get 27DL/5UL. I did a self-install and everything went well without errors. Multiple speed tests from Optimum and speedtest.net show the slower speeds. I checked all connections, hard reset the modem/router, and changed out cables.  Any help would be greatly appreciated.
  • plemans's avatar
    Did you try having them reprovision it?
    Are those speeds hardwired?
    • ScottZ013's avatar
      ScottZ013
      Thank you for the response. Yes, I had them reprovision the modem. As far as the speeds, I am connected directly to the modem via cat 6E cable. Are there any issues with the cable connection or logs? I'm not sure what to look for.
      • plemans's avatar
        Your cable connection looks good but the event logs is the one we need.
