ksk2175
Jun 08, 2023Aspirant
Critical Events on CM1000 - Drop of Internet Multiple time Daily (Xfinity)
2-3 times a day my connection says "no internet" even thought all the lights are solid green on my CM1000 modem. I have a red light on my router for the incoming internet signal. Rebooting the mode...
Jun 08, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
ksk2175
Cable Connection:
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 675000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 44 | 675000000 Hz | 6.4 dBmV | 42.8 dB | 235288719 | 1 | 0 |
| 2 | Locked | QAM256 | 13 | 489000000 Hz | 7.1 dBmV | 45.6 dB | 234440776 | 1 | 0 |
| 3 | Locked | QAM256 | 14 | 495000000 Hz | 7.1 dBmV | 45.5 dB | 234441973 | 1 | 0 |
| 4 | Locked | QAM256 | 15 | 501000000 Hz | 7.1 dBmV | 45.4 dB | 234445647 | 0 | 0 |
| 5 | Locked | QAM256 | 16 | 507000000 Hz | 7.0 dBmV | 45.4 dB | 234449245 | 1 | 0 |
| 6 | Locked | QAM256 | 17 | 513000000 Hz | 6.9 dBmV | 45.4 dB | 234436681 | 1 | 0 |
| 7 | Locked | QAM256 | 18 | 519000000 Hz | 6.8 dBmV | 45.2 dB | 234457056 | 2 | 0 |
| 8 | Locked | QAM256 | 19 | 525000000 Hz | 6.8 dBmV | 45.2 dB | 234460945 | 1 | 0 |
| 9 | Locked | QAM256 | 20 | 531000000 Hz | 6.6 dBmV | 45.2 dB | 234464586 | 1 | 0 |
| 10 | Locked | QAM256 | 21 | 537000000 Hz | 6.5 dBmV | 45.0 dB | 234468947 | 1 | 0 |
| 11 | Locked | QAM256 | 22 | 543000000 Hz | 6.4 dBmV | 45.0 dB | 234472570 | 1 | 0 |
| 12 | Locked | QAM256 | 23 | 549000000 Hz | 6.2 dBmV | 44.8 dB | 234476227 | 1 | 0 |
| 13 | Locked | QAM256 | 24 | 555000000 Hz | 6.3 dBmV | 44.9 dB | 234480396 | 0 | 0 |
| 14 | Locked | QAM256 | 25 | 561000000 Hz | 6.3 dBmV | 44.8 dB | 234483811 | 1 | 0 |
| 15 | Locked | QAM256 | 26 | 567000000 Hz | 6.3 dBmV | 44.7 dB | 234487600 | 1 | 0 |
| 16 | Locked | QAM256 | 27 | 573000000 Hz | 6.3 dBmV | 44.8 dB | 234491881 | 1 | 0 |
| 17 | Locked | QAM256 | 28 | 579000000 Hz | 6.5 dBmV | 44.8 dB | 234495645 | 1 | 0 |
| 18 | Locked | QAM256 | 29 | 585000000 Hz | 6.5 dBmV | 44.7 dB | 234498787 | 0 | 0 |
| 19 | Locked | QAM256 | 30 | 591000000 Hz | 6.5 dBmV | 44.9 dB | 234503011 | 6 | 0 |
| 20 | Locked | QAM256 | 31 | 597000000 Hz | 6.6 dBmV | 44.8 dB | 234508446 | 7 | 0 |
| 21 | Locked | QAM256 | 32 | 603000000 Hz | 6.6 dBmV | 44.8 dB | 234512164 | 0 | 0 |
| 22 | Locked | QAM256 | 33 | 609000000 Hz | 6.5 dBmV | 44.6 dB | 234516028 | 1 | 0 |
| 23 | Locked | QAM256 | 34 | 615000000 Hz | 6.5 dBmV | 44.6 dB | 234519582 | 1 | 0 |
| 24 | Locked | QAM256 | 35 | 621000000 Hz | 6.5 dBmV | 44.6 dB | 234523451 | 1 | 0 |
| 25 | Locked | QAM256 | 36 | 627000000 Hz | 6.4 dBmV | 44.8 dB | 234526947 | 1 | 0 |
| 26 | Locked | QAM256 | 37 | 633000000 Hz | 6.3 dBmV | 44.5 dB | 234530966 | 1 | 0 |
| 27 | Locked | QAM256 | 38 | 639000000 Hz | 6.2 dBmV | 44.4 dB | 234534664 | 1 | 0 |
| 28 | Locked | QAM256 | 39 | 645000000 Hz | 6.2 dBmV | 44.2 dB | 234538124 | 2 | 0 |
| 29 | Locked | QAM256 | 40 | 651000000 Hz | 6.2 dBmV | 44.4 dB | 234541925 | 2 | 0 |
| 30 | Locked | QAM256 | 41 | 657000000 Hz | 6.3 dBmV | 44.4 dB | 234544243 | 1 | 0 |
| 31 | Locked | QAM256 | 42 | 663000000 Hz | 6.4 dBmV | 44.4 dB | 234547678 | 1 | 0 |
| 32 | Locked | QAM256 | 43 | 669000000 Hz | 6.3 dBmV | 44.4 dB | 234551734 | 1 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| 1 | Locked | ATDMA | 17 | 16400000 Hz | 44.8 dBmV |
| 2 | Locked | ATDMA | 18 | 22800000 Hz | 45.0 dBmV |
| 3 | Locked | ATDMA | 19 | 29200000 Hz | 45.0 dBmV |
| 4 | Locked | ATDMA | 20 | 35600000 Hz | 45.5 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1, 2, 3 | 193 | 957000000 Hz | 4.2 dBmV | 41.0 dB | 148 ~ 3947 | 52545052 | 20122956 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 4.0 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| 1 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
Current System Time: Thu Jun 08 07:35:07 2023System Up Time: 1:26:56
- ksk2175Jun 08, 2023Aspirant
...also... I don't have any splitters, attenuators, amplifiers or extended runs ... straight run from wall to modem, modem to router.
- FURRYe38Jun 08, 2023Guru - Experienced User
Ok, power leves are on the high side and a few channels are near the high max value. Might ask the ISP to reduce this by just a bit:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
There is some minor correctables on the down side but not aweful. Mostly should be zeros seen here.
However you have a ton of correctables on the UP side channel 1 which should be zero. The modem is doing over time for unknown reasons on this channel.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/- ksk2175Jun 08, 2023Aspirant
Do you know where the power level ranges should be on these upside channels? Should they be similar to the downside power levels? What is preferable? I will have the ISP come out and test the line. Any chance it might be time for a new updated modem or are all these issues ISP line related? Thanks for you input, I appreciate you time.
Power on the UP is good. With in spec.
What speed tier package do you pay for? The CM1000 only supports up to 1Gb speeds on the DOWN so any packages beyond, you'll not see with this modem. XF reported to split the 1Gb pack into an 800 and 1.2Gb last year and doing away with the 1Gb tier. Causes some problems for some NG modems that could not use 1.2Gb.
