ksk2175
Jun 08, 2023Aspirant
Critical Events on CM1000 - Drop of Internet Multiple time Daily (Xfinity)
2-3 times a day my connection says "no internet" even thought all the lights are solid green on my CM1000 modem. I have a red light on my router for the incoming internet signal. Rebooting the mode...
ksk2175
Cable Connection:
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 675000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 44 | 675000000 Hz | 6.4 dBmV | 42.8 dB | 235288719 | 1 | 0 |
| 2 | Locked | QAM256 | 13 | 489000000 Hz | 7.1 dBmV | 45.6 dB | 234440776 | 1 | 0 |
| 3 | Locked | QAM256 | 14 | 495000000 Hz | 7.1 dBmV | 45.5 dB | 234441973 | 1 | 0 |
| 4 | Locked | QAM256 | 15 | 501000000 Hz | 7.1 dBmV | 45.4 dB | 234445647 | 0 | 0 |
| 5 | Locked | QAM256 | 16 | 507000000 Hz | 7.0 dBmV | 45.4 dB | 234449245 | 1 | 0 |
| 6 | Locked | QAM256 | 17 | 513000000 Hz | 6.9 dBmV | 45.4 dB | 234436681 | 1 | 0 |
| 7 | Locked | QAM256 | 18 | 519000000 Hz | 6.8 dBmV | 45.2 dB | 234457056 | 2 | 0 |
| 8 | Locked | QAM256 | 19 | 525000000 Hz | 6.8 dBmV | 45.2 dB | 234460945 | 1 | 0 |
| 9 | Locked | QAM256 | 20 | 531000000 Hz | 6.6 dBmV | 45.2 dB | 234464586 | 1 | 0 |
| 10 | Locked | QAM256 | 21 | 537000000 Hz | 6.5 dBmV | 45.0 dB | 234468947 | 1 | 0 |
| 11 | Locked | QAM256 | 22 | 543000000 Hz | 6.4 dBmV | 45.0 dB | 234472570 | 1 | 0 |
| 12 | Locked | QAM256 | 23 | 549000000 Hz | 6.2 dBmV | 44.8 dB | 234476227 | 1 | 0 |
| 13 | Locked | QAM256 | 24 | 555000000 Hz | 6.3 dBmV | 44.9 dB | 234480396 | 0 | 0 |
| 14 | Locked | QAM256 | 25 | 561000000 Hz | 6.3 dBmV | 44.8 dB | 234483811 | 1 | 0 |
| 15 | Locked | QAM256 | 26 | 567000000 Hz | 6.3 dBmV | 44.7 dB | 234487600 | 1 | 0 |
| 16 | Locked | QAM256 | 27 | 573000000 Hz | 6.3 dBmV | 44.8 dB | 234491881 | 1 | 0 |
| 17 | Locked | QAM256 | 28 | 579000000 Hz | 6.5 dBmV | 44.8 dB | 234495645 | 1 | 0 |
| 18 | Locked | QAM256 | 29 | 585000000 Hz | 6.5 dBmV | 44.7 dB | 234498787 | 0 | 0 |
| 19 | Locked | QAM256 | 30 | 591000000 Hz | 6.5 dBmV | 44.9 dB | 234503011 | 6 | 0 |
| 20 | Locked | QAM256 | 31 | 597000000 Hz | 6.6 dBmV | 44.8 dB | 234508446 | 7 | 0 |
| 21 | Locked | QAM256 | 32 | 603000000 Hz | 6.6 dBmV | 44.8 dB | 234512164 | 0 | 0 |
| 22 | Locked | QAM256 | 33 | 609000000 Hz | 6.5 dBmV | 44.6 dB | 234516028 | 1 | 0 |
| 23 | Locked | QAM256 | 34 | 615000000 Hz | 6.5 dBmV | 44.6 dB | 234519582 | 1 | 0 |
| 24 | Locked | QAM256 | 35 | 621000000 Hz | 6.5 dBmV | 44.6 dB | 234523451 | 1 | 0 |
| 25 | Locked | QAM256 | 36 | 627000000 Hz | 6.4 dBmV | 44.8 dB | 234526947 | 1 | 0 |
| 26 | Locked | QAM256 | 37 | 633000000 Hz | 6.3 dBmV | 44.5 dB | 234530966 | 1 | 0 |
| 27 | Locked | QAM256 | 38 | 639000000 Hz | 6.2 dBmV | 44.4 dB | 234534664 | 1 | 0 |
| 28 | Locked | QAM256 | 39 | 645000000 Hz | 6.2 dBmV | 44.2 dB | 234538124 | 2 | 0 |
| 29 | Locked | QAM256 | 40 | 651000000 Hz | 6.2 dBmV | 44.4 dB | 234541925 | 2 | 0 |
| 30 | Locked | QAM256 | 41 | 657000000 Hz | 6.3 dBmV | 44.4 dB | 234544243 | 1 | 0 |
| 31 | Locked | QAM256 | 42 | 663000000 Hz | 6.4 dBmV | 44.4 dB | 234547678 | 1 | 0 |
| 32 | Locked | QAM256 | 43 | 669000000 Hz | 6.3 dBmV | 44.4 dB | 234551734 | 1 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| 1 | Locked | ATDMA | 17 | 16400000 Hz | 44.8 dBmV |
| 2 | Locked | ATDMA | 18 | 22800000 Hz | 45.0 dBmV |
| 3 | Locked | ATDMA | 19 | 29200000 Hz | 45.0 dBmV |
| 4 | Locked | ATDMA | 20 | 35600000 Hz | 45.5 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1, 2, 3 | 193 | 957000000 Hz | 4.2 dBmV | 41.0 dB | 148 ~ 3947 | 52545052 | 20122956 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 4.0 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| 1 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
Current System Time: Thu Jun 08 07:35:07 2023System Up Time: 1:26:56
ksk2175
...also... I don't have any splitters, attenuators, amplifiers or extended runs ... straight run from wall to modem, modem to router.
