mpt1123's avatar
mpt1123
Tutor
Mar 12, 2022
CV7000V2 speeds with Xfinity
Hello:
I've upgraded to XFINITY's Extreme Pro Internet which should give me around 800Mbs download.  I don't get anything more than around 200Mbs.  Wired is around 200 and wireless is around 160.  When I swap out the Netgear device with the new Xfinity Xfi device, the speeds increase to around 650Mbs (wireless).  Should I be making a change to the Netgear device to allow for the increased speed.  I hate the idea of having to rent my modem/router from Xfinity.  The Netgear device is a C7000V2 modem/router at firmware level V1.03.03.
Thanks.
  • plemans's avatar
    did you try factory resetting the c7000 and reinstalling it? Test its speed in the default configuration
    • mpt1123's avatar
      mpt1123
      Tutor
      No, I haven't.  Will I need to get Xfinity involved after I do the reset?
      • plemans's avatar
        If its connected and working, no.
        If you had your xfinity box reprovisioned to your service, then maybe to get it reprovisioned.
