jaross913
Jul 12, 2021Aspirant
Daily modem errors in log losing connection
Modem needs reset almost daily, or more, to restore ISP connectivity. ISP says good signal on their end, but I'm not so sure. The log is very sketchy and I'm not sure what I'm looking at. Thoughts?
jaross913
Cable connections now attached.
DarrenM
Jul 14, 2021Sr. NETGEAR Moderator
I am seeing T3 timeouts in the logs this is typically a issue with your ISP connection you may want them to send a tech out to check your lines. Also does you modem have a cable splitter on it where the cable line comes out of the wall and splits between your modem and a cable box? If so you could try to remove that splitter and connect the modem direct to the wall.
DarrenM
