jaross913
Jul 12, 2021Aspirant
Daily modem errors in log losing connection
Modem needs reset almost daily, or more, to restore ISP connectivity. ISP says good signal on their end, but I'm not so sure. The log is very sketchy and I'm not sure what I'm looking at. Thoughts?
Jul 14, 2021Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
