JoeB10000
Sep 22, 2016Aspirant
device does not have wifi signal c6300
I purchased the netgear c6300 wifi modem router combo, everything is installed and up to date, cable works just fine. the wifi works upon reboot for anywhere between 30 seconds to a couple hours but ...
DarrenM
Sep 23, 2016Sr. NETGEAR Moderator
Hello JoeB10000
Have you tried to change the wireless channel? Or try to lower the wireless speed.
DarrenM
- JoeB10000Sep 24, 2016Aspirant
Tried both options. With no change.
I am not sure i understand how changing the speed of the wireless signal would affect the devices failure to broadcast any signal at all.
- basilbrooksSep 25, 2016Aspirant
Hello there
Just a thought as I do not know what Devices/OS you are connecting to the router or what your overall environment is?
I do know that wirelss problems can be a pain to deal with as you can get interference from a range of electrical devices, other networks on the same or neighbouring channels, or just the router getting hot and failing or a bug in the firmware?
Have you tried using a wireless diagnostic program/app. I used to have a good one on Windows, which showed all the available wireless networks and there relative strengths etc. I don't have anything on my Mac at the mo (though I think there might be something built in) but I do have a good one on Android called OpenSignal which shows both mobile and wifi sigals. Just google something like "wireless diagnostic app/program your platform" and see what comes up.Hope this helps to get to the bottom of it.
Cheers Basil
