amyallan153
Feb 28, 2017Follower
device will connect others say no internet connection and connected devices drop
I just bought this router yesterday and the CM700 Modem, the modem works great! However, I'm about ready to have a fit with the router. I have 2 devices that will connect to the wireless router all o...
storm1985
Mar 01, 2017Prodigy
if you can go online directly to your CM700 then check your router internet settings.
if it is a NETGEAR router follow this this KB.
aalexandrebeta
Mar 01, 2017Master
Try factory reset and keep me posted!
Regards from a Frog!
