drew-k
Nov 15, 2024Aspirant
Devices Disconnect but Reconnect After Reboot
Not sure if this is the right board...
I have a Nighthawk DOCSIS 3.1 Two-In-One Camble Modem + Wifi Router.
Rather frequently now, certain devices disconnect from the internet. For example, my Flo device which detects leaks in our basement. And, my Chargepoint in my garage. While the internet works fine on my wifi devices, these seem to disconnect. The only way to get them back online is to restart the entire Modem/Router.
Any idea why certain devices might disconnect? Why would rebooting the router fix it?
Time for a new router?
Thanks!
Drew
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
How many WiFi devices do you have?
How big is the home in Sq feet?
What is the distances from the gateway to these devices?
Is Smart Connect enabled or disabled on the gateway?
- drew-kAspirant
I'll try to answer these. I'm not an expert...
It's set to Auto. What will changing the channels do? Curious...
Hard to tell because some are no longer connected. I would guess 12-15? The Flo device has a "hub." The Chargepoint is in our garage but uses an extender that goes through the electrical outlet.
1500SF
Not far, especially since the Flo hub is next to router.
Don't know how to check this.
Thanks!
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz...Help with noise or interferences from neighboring Wi-Fi signals.
How many Wi-Fi devices do you have?
Is this extender something you added on for additional wifi coverage? Brand and model# of this extender?
What is the distance between this extender and the gateway router?
1500SF
How close is the hub next to the router? Distances from the router to devices should be 6 feet minimum.
Log into the routers web page and under Basic tab/Wireless settings. Should see something call Smart Connect here.
Also see if there is any additional Wi-Fi features on the routers web page under advanced tab/advanced settings/Wireless settings.
