gwass
Jan 12, 2019Aspirant
dgn1000v3 I want to configure it in acess mode not bridge mode.
I have a DGN1000v3 that I want to use as an Acess point. Not bridge mode
Is there a way to do this Keep seeing I must change AP but no AP on my router to change
Tried different firmware ...
- Jan 12, 2019
Connect the computer wired to any of Local ports (1-4)
Access the admin page
Configure the Wireless Settings of rhe ADSL modem/router
Go to ADVANCED > Setup > LAN Setup.
Change the Ip address in the LAN TCP/IP Setup within the same range of your existing network. (by Default the IP 192.168.0.1)
Uncheck "Use Router as DHCP Server" and click Apply
Connect the any Local ports (1-4) to existing network.
Check the if you can connect wirelessly
Hope this help to setup the ADSL router as AP mode.
Nodism1125
Jan 12, 2019NETGEAR Expert
- gwassJan 13, 2019Aspirant
That worked. Thanks very much
