gwass's avatar
gwass
dgn1000v3 I want to configure it in acess mode not bridge mode.
I have a DGN1000v3 that I want to use as an Acess point.   Not bridge mode     Is there a way to do this    Keep seeing I must change AP but no AP on my router to change Tried different firmware ...
  • Nodism1125's avatar
    Jan 12, 2019
    Connect the computer wired to any of Local ports (1-4)
    Access the admin page
    Configure the Wireless Settings of rhe ADSL modem/router
    Go to ADVANCED > Setup > LAN Setup.
    Change the Ip address in the LAN TCP/IP Setup within the same range of your existing network. (by Default the IP 192.168.0.1)
    Uncheck "Use Router as DHCP Server" and click Apply
    Connect the any Local ports (1-4) to existing network.
    Check the if you can connect wirelessly
    Hope this help to setup the ADSL router as AP mode.
