Liquidtravel
Sep 29, 2019Aspirant
Differences between Nighthawk AC3200 X4 Wi-Fi Router C7500 and the Nighthawk AC3200 X4 Wi-Fi Router
Hello all,
I am trying to find out the differences between Nighthawk AC3200 X4 Wi-Fi Router C7500 and the Nighthawk AC3200 X4 Wi-Fi Router C7800. I can find reviews of each but the C7800 seems to be more prevelant that the c7500.
Can anyone point me in the right direction.
thanks
You can download the spec sheet for each model here:
https://www.netgear.com/support/
Type in the model# then select "Documentation".
- LiquidtravelAspirant
thanks. So the only real difference is the DOCSIS 3.0 vs DOCSIS 3.1 cable modem?
IF thats what you see in the spec sheets...
