desparate
Oct 26, 2016Aspirant
Disable factory reset on Nighthawk C7000 modem/router
Is there a way to disable the factory reset button? Unless the router is physically secure, any person (minor but smart family members) can reset the router and connect to the internet bypassing a...
- Nov 02, 2016
Hello Desparate
Yes you can just turn off broadcast the SSID and on your devices you will have to use the manual connect option and enter the name of the SSID.
DarrenM
desparate
Oct 27, 2016Aspirant
Or just remove/scratch the password info label from the box before first installation. Too late for me now but hope it is useful for others having a similar problem.
Thanks for the reply.
