desparate
Oct 26, 2016Aspirant
Disable factory reset on Nighthawk C7000 modem/router
Is there a way to disable the factory reset button? Unless the router is physically secure, any person (minor but smart family members) can reset the router and connect to the internet bypassing a...
- Nov 02, 2016
Hello Desparate
Yes you can just turn off broadcast the SSID and on your devices you will have to use the manual connect option and enter the name of the SSID.
DarrenM
desparate
Oct 31, 2016Aspirant
No tape will keep away the pest I have! I rewired the cables and moved the router to a different room out of sight. Let's see how long this would work since the location can be traced through the signal strength now. Is it possible to connect to a network without advertising it's name?
- DarrenMNov 02, 2016Sr. NETGEAR Moderator
Hello Desparate
DarrenM
